Previous in Forum: Turbine - Drop in Back Pressure and Increase in Nozzle Box Pressure   Next in Forum: Piping NDE
Select a Motor For Agitator
12/27/2010 10:49 PM
I want to know how to select a suitable motor for agitator of a mixing tank
Re: Select a Motor For Agitator
01/01/2011 11:33 AM
Starting and running torque are the first parameters to consider when sizing electric motors. Starting torque requirements for electric motors can vary from a small percentage of full load to a value several times full-load torque. Starting torque varies because of a change in load conditions or the mechanical nature of the machine, which the electric motor is installed in. The latter could be caused by the lubricant, wear of moving parts, or other reasons. Electric motors feature torque supplied to the driven machine, which must be more than that required from start to full speed. The greater the electric motor's reserve torque, the more rapid the acceleration. Electric motor drive systems that use gear reducers have parts that rotate at different speeds. To calculate acceleration torque required for these electric motors, rotating components must be reduced to a common base. The part inertias are usually converted to their equivalent value at the drive shaft. Equivalent inertia W2K22 of the load only is found from: W2K22 =(W1K12)(N1/N2)2 where W1K21 = load inertia in lb-ft2, N1 = load speed in rpm, and N2 = electric motor speed in rpm. Electric motors have bodies, which have a straight-line motion are often connected to rotating driving units by rack-and-pinion, cable, or cam mechanisms. For these electric motor parts, the equivalent WK2 is found from: WK2 = W(S/2ΠN)2 where W = load weight, S = translation speed in fpm, Π is pi, and N = rotational speed in rpm.
01/04/2011 11:48 AM
Contact the agitator suppliers with full details of the tank and its contents and let them do it instead.
