Previous in Forum: GIC Grain Silo   Next in Forum: Hydraulic Cylinder Press for 850 Tons
8 comments
Buried Pipeline vs Aboveground Pipeline
12/28/2010 12:49 PM
In Pipeline configurations we see Buried Pipelines as well as Above ground pipelines.What circumstances separate their this use as buried as well as above ground pipeline?
Good Answers: 181
Re: Buried pipeline Vs Aboveground Pipeline
12/28/2010 1:06 PM
The circumstances are:
A/ you don't want to see it
B/ you want to see it
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
12/28/2010 1:07 PM
From my experience pipelines are always buried (for protection) until it becomes cost prohibitive to dig the trench (typically rocky areas). In all cases that I installed pipe above ground, it was simply cost driven.
Sometimes my thoughts are in a degree of order so high even I don't get it...
Re: Buried Pipeline vs Aboveground Pipeline
12/29/2010 1:12 AM
You need cathodic protection for UG pipes and leaks cannot be seen but safe from mechanical damage.
pnaban
Good Answers: 38
12/29/2010 10:06 AM
Cathodic protection is not universally required for underground piping. It depends on the materials used and the intended design life. I have not heard of or designed any concrete, PVC, ductile iron, or HDPE piping systems with cathodic protection. In fact the only material I have seen with CP is steel.
Good Answers: 181
12/30/2010 5:46 AM
Ductile iron uses zinc for cathodic protection, during manufacture they are spray coated (metalised) with zinc. Used along with a sacrificial anode any damage to the protective coating results in a zinc blister forming protecting the ductile.
Good Answers: 38
12/30/2010 2:09 PM
This might be a difference in the norm between countries or perhaps a difference in pipe design criteria. I've never heard of such a thing here in the US.
01/03/2011 5:36 AM
ug piping requires wrapping and cathodic protection for steel pipes.
site physical feasible conditions,HSE stabdards also having affective role in differentiation between AG and UG
03/24/2025 7:01 AM
It is rate for drainage and sewage piping to be <...Above ground pipelines...>.
ChaoticIntellect (3); pnaban (1); PWSlack (1); suvarna_mendu (1); TonyS (2)
