Previous in Forum: Good Question?   Next in Forum: Credible UFO Testimony
Bevel End for Pipes & Fittings According to B16.25
12/30/2010 1:37 AM
What are the effects is we go for Fig 4 ( B16.25) instead of Fig 5 type A or B.
As some vendor are reluctant to make the bevel ends according to Fig 5 , because of hard design.
What benefits Fig 5 offers over fig 4 and can we really go for Fig 4 instead of fig 5?
Re: Bevel End for Pipes & Fittings according to B16.25
12/30/2010 1:44 AM
Can you please reproduce those figures, or at least describe the geometry involved?
Re: Bevel End for Pipes & Fittings According to B16.25
12/30/2010 11:18 PM
• At ASME B16.25, the various piping components end joints preparation are detailed at Fig. 3 for those bevels other than GTAW root pass, where Fig. 4 and Fig. 5 are for those bevels for GTAW root pass.
• And it is the purchasing responsibility to specify the type of joint preparation, where the standard shall be as Fig.3, unless the purchaser selects the GTAW procedure for welding as illustrated at Fig. 4 or Fig. 5.
• Also, when the process is other than GTAW, it is the responsibility of purchaser to specify using of backing ring or not. And in case of using backing ring, it is the purchaser responsibility to select its type to suit the end joint preparation. See Fig.3 (a), (b), (c) and (d).
01/24/2011 2:55 AM
Dear Mr.Galala,
I have some query to ask -
Does it is important to mention every time "C" dimension calculated using B16.25(page-3 of 2003)in weld end preparation of two pipe spool even though pipe has same nominal OD and same nominal thickness and using fig.2a/2b.
C=A-OD tolerance-2*tmin-0.25.
Where,
A-Nominal outside diameter.
OD tolerance-undertolerance on OD(This value come from SA530 Table-1)
In case of A106 or A335 pipe above can be modified as-
C=A-0.79-2*tmin-0.25
C=A-0.79-2*0.875*tnominal-0.25
Here
tnominal=tmin/0.875.(12.5% mill undertolerance on pipe thickness)
For example -
Nominal OD-508mm
Nominal thicknes-S60(20.62mm)
So,C dimension
C=508-0.79-2*0.875*20.62-0.25
C=470.875mm.
So,for higher thickness does we have mention mention "C" dimension rather than nominal inside diameter for every weld.
Also,as per ASME B31.1,in case of inside thickness difference is greater than 2 mm internal trimming has to done.(explained below)
As per SA350 Table-1,(for 20" NPS pipe)
Over tolerance on OD,+3.2mm
undertolerance on OD,-0.8mm
and considering 12.5% under and over tolerance on pipe thickness,
NOMINAL WALL (mm),from B36.10t
n
20.62
ACT MIN WALL (mm),-12.5% mill tol.T
min
18.04
ACT MAX WALL (mm),+12.5%mill tol.T
max
23.20
MAXIMUM OUTSIDE DIAMETER (mm)
511.20
MINIMUM OUTSIDE DIAMETER (mm)
507.20
MAXIMUM INSIDE DIAMETER (mm)
475.12
MINIMUM INSIDE DIAMETER (mm)
460.81
SO,if we minus MAXIMUM INSIDE DIAMETER (mm) and MINIMUM INSIDE DIAMETER (mm),475.12-460.81=14.31mm,14.31/2=7.155 which is higher than 2mm (as per ASME31.1).In this case we have do trimming.
Conclusion
So,do we have to do trimming for each and every weld in case of higher pipe thickness as every time we will get inside thickness difference more than 2 mm and what dimension we will be showing on weld end preparation,either "C" dimension or "B"(nominal inside diameter) dimension from B16.25.
What is your explaination on this topic.
Register to Reply 3 comments
Abdel Halim Galala (1); Lahane82 (1); Tornado (1)
You might be interested in: Hose Fittings, Tube Fittings, Bevel and Miter Gears
