Previous in Forum: Small Bore Gaps for Sockets   Next in Forum: Looking for swaged hook for wire rope
Selecting Material and Hardening Process for Steel
12/30/2010 3:20 AM
I wanted to select material and hardening process for steel.Application is Cranes and excavtors pins and bush.As these are under high shocks and wear resisting properties.Which material should i take for pin and bush .Also hardening process for both?
We use EN 19 for Pin and EN 353 for bush .For pin induction hardening 45-50 HRC.And for Bush Case hardening 50-55 HRC .Is this correct?
Good Answers: 243
Re: Selecting Material and Hardening Process for Steel
12/30/2010 10:13 AM
This is a job for a professional engineer to study the loads and designs and necessary safety factors.
No free guesses from me.
Milo
Reply to Forum Thread
You might be interested in: PIN Diodes, IC Pin Probes, Plug and Pin Gages
