Previous in Forum: Mazak X510 2500 Watt Laser/Will It Cut Lead Plate   Next in Forum: Selecting Material and Hardening Process for Steel
Good Answers: 34
Small Bore Gaps for Sockets
12/30/2010 3:02 AM
Talking about small bore sockets: Which is the minimun and maximun gap for expansion between the fitting and the insert pipe?.
I´m using my own acceptance criteria, minimum:1mm and Max: 1/3 of the Depth of the fitting hole. I do not find any reference in codes or procedure.
Another problem is how to messure this gap on a radiographic film?
Happy new year for all of you
Re: Small bore gaps for sockets
12/30/2010 3:41 AM
This is really anal. Just find a bigger cork. Sorry.
Good Answers: 34
12/30/2010 5:33 AM
Thanks for your fast answer.Waiting no less from you. Yes,finds it, sure, sending to you.
Regards and have a nice new year.
Re: Small Bore Gaps for Sockets
01/03/2011 8:15 AM
Socket gaps are clearly defined in the ASME Boiler and Pressure Vessel Code. Have you looked there? Also, NavSea 250-1500-1 describes it as well. Do you have access to either of those?
Register to Reply 3 comments
Tornado (1); weldeng449 (1); Whitephone (1)
