i erect pre-fab commercial buildings that have a metal framework that's enclosed with metal sheeting that's painted on both sides. these buildings are well designed for the most part. the major problem with these type of buildings is that the roof sheets corrode around the cadmium plated screws and rubber washers that holds the roof to a heavily painted [red oxide? steel framework. the sides don't seem to have this problem, though the method is identical. the cororsion is a fine grey powder that looks alot like battery corrosion. i contribribue it to electrolysis, though i'm not familar with the electrical aspect. that part is done my engineers and certified electrictions.
would a sacrafical metal between the building and ground solve the problem?
