Previous in Forum: Spring Loaded Dial Calipers   Next in Forum: Corroded Stainless Steel (303) Nuts in Tank
Design Standards for multi-barbed hose fittings
03/26/2007 10:09 AM
Can someone respond with ISO, DIN, GM, etc. design standard for multi barbed hose fittings? A Nerac search turned up no industry standards for barbed hose fittings.
There is SAE J1231 & J1697 for single bead hose barb fitting.
However, I can't find a standard for multi-barbed hose fitting.
I am interested in dimensional specifications/standards for plastic injection molded design of barbed hose fittings, for custom engineered components, that need to be connected to fuel hoses, with & without a hose clamp. Over time our company has made fittings to various dimensions & different shaped barbs. Now I am trying to clean up designs & standardize to find a common dimensional design.
thanks for your input.
Here are examples:
Lucy
Pathfinder Tags: Hose Fitting Multi Barbed
Re: Design Standards for multi-barbed hose fittings
03/27/2007 7:07 AM
Try SAE J512
03/27/2007 9:07 AM
Thank you for suggestion SAE J512. I looked into this std and it showed pipe fittings and compression fittings.
What I am looking for is a dimensional standard for plastic hose barbed fittings that would specify industry standard dimensions of barb OD, shank OD, number & spacing between barbs, radius at tip of barb, and angle of barb. Also need dimensions for hose joint using a hose clamp, and for hose joint not using a hose clamp, in case they have different recommended sizes.
thanks,
Lucy
Lucy
Register to Reply 2 comments
You might be interested in: Hose Fittings, Air Hose and Air Duct Hose
