Previous in Forum: Voltage Setting in GCP30 Series   Next in Forum: High Electric Bill for Residential House
Main Breaker Based on 3Ph or 1Ph
01/03/2011 12:35 AM
As we know that 1Ph draw more current and 3Ph draw less current to balance the VA rating.I have some confusion during load calculation. In 3 phase panel load center, some load as a single phase(2P breaker,Ph&N) and some load as a 3Ph(R,Y,B),so our final load calculation based on 3ph(square root 3) or 1Ph for main breaker,. So could any one tell me the answer
Re: Main breaker based on 3Ph or 1Ph
01/03/2011 1:04 AM
Connect a power analyser and record Amp drwan in each phase during working hours and decide the rating of CB.If load is unbalanced you should balance it.
pnaban
01/03/2011 4:09 AM
The breaker must be sized so as to prevent the cables taking too much current. British Standard 7671 tells all.
01/03/2011 2:25 PM
PWSlack is correct, but I'd amplify his answer a little (I did give him a GA):
  • The NEC also "tells all".
  • The outgoing breakers from this panel are sized to protect the conductors going to the loads. If you also want more precise protection (like for a motor), you need to use supplementary protection (like a motor starter with overload protection).
pnaban (1); PWSlack (1); rhkramer (1)
