Previous in Forum: The large bubbles in quality bread   Next in Forum: Stud welding query
Thermal profile of hot Billet / Slab
03/26/2007 11:50 PM
What is the desirable thermal profile along the length & width of a billet (W=100mm x H=100mm x L=10,000mm) / slab (W=1000mm x H=200mm x L=10000mm mm) achieved at the end of soaking inside a reheating furnace if the rolling duration is 6-7 minutes approximately and at the end of last stand the finishing temperature is say 800°C all along the length of the slab?
Regards, SD
User-tagged by 1 user
Re: Thermal profile of hot Billet / Slab
03/28/2007 2:59 PM
Variable from 400 Deg C to 800 Deg C.
03/30/2007 4:21 AM
________________ History of Hot Rolling Types of Hot-Rolled Products Casting Practices The Reheating of Ingots Conditioning Semi-Finished Products The Basic Principles of Rolling and Pass Design Blooming, Slabbing, and Billet Mills.Reheat Furnaces Bar and Rod Mills Structural Mills The Rolling of Rails, Wheels, and Rings Tube Mills Plate Mills Hot-Strip Mills Mill Drives Mill Rolls and Bearings The Cooling of Mill Rolls The Cooling and Descaling of Workpieces Mathematical Models of Hot, Flat Rolling The Behavior of Steels During Deformation at Elevated Temperatures Controlled Rolling or the Thermomechanical Treatment of Steel Frictional Effects in Hot Rolling Nonuniform Deformation in Hot Rolling.Heat Treatments for Hot-Rolled Products The Instrumentation and Computer Control of Hot Mills The Further Processing of Hot-Rolled Products
MARCEL DEKKER - TAYLOR & FRANCIS - CRC
__________________________-
H ISBN: 0824713451 PGS: 1034 List: 289.95 YOUR PRICE: 275.45
TATA will have to buy and find out.
And the post#1 friend says 400>800°C!
400 will break the rolls.More like 780>800°C!
Register to Reply 2 comments
