Previous in Forum: HVAC   Next in Forum: Removing Lime Buildup in HVAC Systems
Cryogenic Storage Tanks
01/05/2011 12:02 PM
Cryogenics storage tanks are generally used for low temperature product say less -63 deg ie...Nitrogen... etc tanks used are generally double wall tanks w/h insulation bet them..........what is purpose of double wall n is it possible using normal single wall tanks with sme tracing system to hold the product at its lowest temp jst like refrigeration?
Good Answers: 299
Re: storage tanks
01/05/2011 12:10 PM
"...what is purpose of double wall ..."
Vacuum.
Re: storage tanks
01/05/2011 12:19 PM
double wall is generaly two tanks........inner tk n outter tk between which insulation is provided to avoid heat transfer frm product to atm.............bt is it realy necessry?
Re: storage tanks
01/05/2011 12:40 PM
Yes, it is necessary. Without insulation, you would lose a lot more due to evaporation.
Re: storage tanks
01/05/2011 12:53 PM
brendan..
No, it is not really necessary. You have discovered our deepest, darkest engineering secret.
Please, do not tell the others.... keep the double walled tank farce within our special group....
Thanks...
Good Answers: 299
Re: storage tanks
01/05/2011 1:07 PM
brendan4, did you check the link in #1 to the Wikipedia article about Dewar Flask?
Read the article, and all most will be revealed.
Do you have a pet cuckoo bird?
Re: Cryogenic Storage Tanks
03/25/2012 2:44 AM
what the code applied for fabracation and inspection for double wall tank?
Register to Reply 6 comments
Anonymous Poster (2); brendan4 (1); Doorman (2); Mikerho (1)
