My preferred method for an even blue is to place the (re-polished) part/s on a larger block of 'barely red' steel and let it "soak" in, or through, or up.
Some practice is required to estimate how red by what mass, makes what thickness/mass arrive at the right shade of blue.
Fine wire, or mesh, is handy as a stand off, if the work is of large mass, so requiring a 'hotter' base block.
This method will also produce even 'straw', which is quite difficult with direct flame techniques.
Having arrived at the desired colour, quench in oil to freeze the temper.
Go to your local, or online, gun shop and ask for "gun blue".
It comes with instructions.
It is a bit nasty, so disposable gloves and ventilation are good ideas.
You may need to boil parts, in bags with chemicals, in a water filled vessel (depends on the system)
You will need a 'finishing oil' for the process, which has some impact on 'maturing the color'.
However; though I do it for repairs and the odd restoration, I'm sure there are a bunch of more expert 'mericans just busting to tell exactly what to buy and how to do it best.
And just quietly, I wouldn't mind listening to that.
