Previous in Forum: How to Convert and Transfer Video to iPad?   Next in Forum: Audio Extraction
11 comments
Good Answers: 97
How to Reinvigorate that Tired Old Computer
01/08/2011 12:22 AM
http://puppylinux.org/main/Overview%20and%20Getting%20Started.htm
Re: How to reinvigorate that tired old computer
01/08/2011 12:44 AM
Not for newbies.
Charlie don't surf.
Good Answers: 97
01/08/2011 12:54 AM
Download a live version of Linux, I'd suggest Puppy. Use software on the a newer computer to burn the iso image to a CD. Insert the CD in the old computer and set the BIOS to boot from the CD. Purchase a 8GB or 16GB flash drive (I'm assuming the old computer has a USB port) With the live Linux CD running mount the HD, search it for pictures by going to Documents and Settings folder and finding your user name. Then find your My Documents folder and in it will by Pictures. With the flash drive inserted in the computer mount it (by clicking on it) and drag the Pictures folder to the flash drive. Once you've done that you can use your other CD's to restore the computer and then copy the pictures back. If you have more pictures than fit on the flash drive copy them to a new folder on the new computer, delete them on the flash and copy more pictures until you have them all copied. Use NERO, Roxio or Sonic to burn image to cd. You can find Puppy at http://distro.ibiblio.org/pub/linux/distributions/puppylinux/puppy-5.2/lupu-520.iso and use the same instructions above.
01/08/2011 3:08 AM
Then watch GRUB hose your MBR and make your XP box unbootable.
Charlie don't surf.
Good Answers: 97
01/08/2011 4:21 PM
Exactly the point, err.....thats the gist of this issue to toss the XP in favor of a lite O/S for the tired old puter.
Good Answers: 213
01/08/2011 11:01 PM
I have been running Ubuntu with XP for several years now, and have had no trouble with GRUB hosing the XP sector. But I haven't updated XP for a long time now, and I never expose my Windows sector to the Internet. No problems. I have read somewhere that some Windows applications secretly store licensing information in the boot sector, which is where GRUB resides. I suspect the problem is with MS policy, which allows writing to the boot sector, is more at fault than GRUB. I did notice on a recent rebuild of the Linux sector to a newer version, GRUB changed significantly (I am not sure of the version numbers) but the XP sector still behaves normally.
You don't have to be that much of a geek these days to enjoy Linux- the other day I was visiting a client, and happened to notice she was running Ubuntu on her computer. When I commented on the fact, she responded, "I haven't the slightest idea what I am running- a friend of mine set it up. All I know is that it works!" Obviously not a geek...
Good Answers: 97
01/08/2011 11:52 PM
I believe the3 intended use for Linux - Puppy is to run from a flashdrive and specifically to enable unbunggling Windows machines. Also it is designed be run from any computer, so you can go visit and plug your Puppy in and do your online banking etc. form the flashdrive and not touch the HDD.
Good Answers: 114
01/09/2011 2:02 AM
I had a dual boot [with XP] for more than a year, never had a problem [your mileage may vary]
I'm running mint9 from a flash drive, on a laptop without a hard drive
it will run on any computer that will boot from usb [with all my settings & little programs]
I just set up a different computer with Mint9 this afternoon that has a 1.1ghz processor & 256mb ram
You do have to wait a couple of minutes for a youtube video to load, but you can watch
If I do too many things the screen will go gray, but I couldn't make it crash, I certainly could make it crash when it was an XP machine this morning.
I would suggest that if you want to do a dual boot, do it by adding a dedicated hard [or flash]drive for each operating system, all the different linux variations [distros] will easily see your files on the windows hdd
There are only a few things that work better on a windows box:
a few games & netflix
Puppy is really small, but the cost is you have to set up
01/08/2011 3:06 AM
Geritol.
(What the hey--it worked for Lawrence Welk, or vice versa.)
01/08/2011 7:06 AM
Or, if you're running XP or Win 7, and it ain't broke, leave it alone.
I installed Linux on my hard drive alongside Win 7. I got it working, and then spent 2 days undoing everything..................like steve said, it's not for newbies, it requires a certain degree of computer geekiness, conflicts arise with Windows, etc.
If someone really just wants a computer that works nicely without a lot of heartache, spend the extra money and get an Apple.........which I don't have.
Not that Linux isn't a good OS...............but there's more to it than just downloading and running with it. At least there was for me.
Good Answers: 119
01/08/2011 2:41 PM
Some seem to be missing the title/subject of your post. The "tired old computer" is the important factor. There are many lower end Pentium/AMD boxes with sub-GHz clocks and sub-GB ram that just won't even run XP after service pack 2 upgrades. I've tried and the results are laughable. However, distros like "Puppy Linux" or "DSL" load and run fine on many of these old boxes.
With a light Linux, these old PCs can perform general office/email tasks with ease. Simple web surfing (no streaming HDTV) is also quite tolerable. Fitted with newer/larger drives, these old boxes can be re-tasked as home network storage (NAS) or file servers. Yes, some geek factor is needed. Most people will just give up and send the old PC to the landfill. Too bad really because some can remain quite useful with just a little effort.
01/08/2011 10:57 PM
I have found a good home for two or three old pentium 2 to 4 laptops.
Suggestions- Use them for a specific function.
like- Stepping motor control even under DOS. A very old thinkpad drives my telescope very well.
Security systems- an old pentium 4 runs my HD security tv system perfectly with all the features that I need, including motion detection and storage of video.
Mapping or reference applications- An old pentium 2 under Windows 98/2 runs my Astronomical chart referencing software and displays star maps in my observatory fine.
Basically the older the machine the less flexible it is. It doesn't mean that you can't find a use for it.
Register to Reply 11 comments
Anonymous Poster (1); bwire (3); cwarner7_11 (1); Garthh (1); kramarat (1); mjb1962853 (1); stevem (2); Tornado (1)
