Previous in Forum: Mechanical Metric Micrometer   Next in Forum: Vortex Flow Meter
11 comments
Cable Size
01/08/2011 12:53 AM
Hi,
As per NEC standards 18 AWG cable size is equivalent to 0.83 mm2 cross section area
when we compare this with BS /IEC 18 AWG works out to 1.0mm2 , this is same to
18/16/14 AWG cable size,
Just for rounding off -- 1.0mm2 was considered or for some other reason
Regards
Jose John
Re: Cable Size
01/08/2011 4:46 AM
AWG is an acronym for "American Wire Gauge".
Where are you finding data for "British Standard" AWG?
Good Answers: 116
Re: Cable Size
01/09/2011 11:53 AM
I guessed there was a "missing" comma after BS/IEC. It just shows that punctuation is not irrelevant! It's a good thing engineers are not lawyers, or one would spend days arguing what a specification meant.
Re: Cable Size
01/09/2011 12:55 PM
"It's a good thing engineers are not lawyers, or one would spend days arguing what a specification meant"
You're new here, aren't you. We spend days arguing about much less important things than that!
Re: Cable Size
01/09/2011 5:22 PM
Good Answers: 116
Re: Cable Size
01/10/2011 3:32 PM
You're so right! You must mean like "What is this device" thread.
Is there an archaeologist's web site it could be tried on?
Good Answers: 116
Re: Cable Size
01/08/2011 5:25 PM
  1. BS standard cable sizes go 0.5,0.75, 1.0, 1.25, 1.5, 2.5 sq.mm - logical since cross-sectional area is major factor for cables.
  2. AWG is based on solid round wire section, like old BS. It does not appear to have a logical pattern - maybe it is based similarly to shotgun gauges, which are I believe based on the number of spherical balls, fitting the bore, which you can get out of a pound of lead.
  3. When you look at several makers versions of multi-strand flexible "16 AWG" wire, there is a surprising variation in square millimetres copper area, with different strandings etc.( a variation of 1.2 to 1.3 sq. mm comes to mind)
  4. At least with BS/IEC you know well how much copper you get for your money!
  5. The twist in a stranded cable does affect the resistance, because each conductor is not straight, but a spiral (except one in middle!).
Re: Cable Size
01/09/2011 12:10 AM
Whether it is AWG or BS what is important is the effective cross section. Diameter can vary for different constructions like,solid,stranded or flexible.Skin effect too should be taken into consideration.
pnaban
Re: Cable Size
01/09/2011 12:53 AM
Thanks For all the Anwswers
Regards
Jose
Good Answers: 75
Re: Cable Size
01/09/2011 8:25 AM
It is believed that the gauge number of a wire corresponded with the number of time the wire had been drawn to make it smaller.
For example after drawing the blank once you would have 1 gauge wire, draw it a second time gives 2 gauge and so on.
Of course the reduction in diameter and cross sectional area of each drawing process varies with material and numerous other factors so that's probably why there are so many different wire gauge standards in use throughout the world.
Personally I like to see things measured directly either a diameter or cross sectional area, as it makes things fare less likely to be misinterpreted.
Re: Cable Size
01/09/2011 10:17 AM
Even for same cross sectional area current rating will depend upon type of conductor-solid,sector,circular or tubular
pnaban
Re: Cable Size
01/11/2011 6:37 PM
Hurrah for British Standard 7671, then.
67model (3); JohnDG (2); josej (1); lyn (1); masu (1); pnaban (2); PWSlack (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
