Previous in Forum: Hydrotest & Pneumatic Test   Next in Forum: Help for Design Microhydro Turbine...
ASTM A106GRB AND ASTM A53GRB
01/08/2011 8:26 AM
Whats difference b/w A106 GR B and A53 GR B. are they same ,then why this classification
Good Answers: 243
Re: ASTM A106GRB AND ASTM A53GRB
01/08/2011 1:31 PM
A 106 covers only seamless pipe and presumes high temperature service.
A53 also lists ERW (type E) and Furnace welded (type F) You could order Astm A 53 Type E Grade B and that would be a welded, not seamless pipe.
ASTM A 106 only recognizes Seamless for the pipe. And does not recognize hot dipped galvanized. A 53 also recognizes Hot Dipped galvanized.
The formula for calculating minimum elongation (note to table 2 in each of these. also appears to be different. The A 53 has an additional factor.
Engineers specify what they specify because they want to assure attributes and properties, such as NO zinc or Zinc, No weld, or weld. etc.
Milo
Milo
Reply to Forum Thread
