Previous in Forum: Flourescent Lighting Question   Next in Forum: Generator Isolated Operation
DSDR
01/08/2011 10:00 AM
why do we mention frequency and voltage in case of power distribution specification?
Re: dsdr
01/08/2011 10:06 AM
Because that makes more sense than mentioning air speed and altitude.
Is there really a question here?
Good Answers: 116
Re: DSDR
01/08/2011 3:47 PM
Because :-
  1. Voltage too low - customers lamps go dim etc.
  2. Voltage too high - customers lamps go very bright then fail etc.
  3. Frequency too low (voltage normal, or worse, high) - customers' transformers overheat. Most motors run slower in proportion to frequency.
  4. Frequency too high (voltage normal, or worse, low) - Motor driven loads like fans and pumps run faster (% increase in load is twice increase in frequency e.g 5% frequency increase causes 10% load increase) and can be overloaded.
  5. Everything "AC mains" electrical you buy is designed to work at nameplate voltages and frequencies with small variation from them. If distribution voltage/frequency were not coordinated with that, many would not work well or fail quickly.
Good Answers: 804
Re: DSDR
01/09/2011 2:20 PM
Adjusted to be relevant to "power distribution system", meaning the ENTIRE transmission system used by utilities.
  1. Voltage too low - Nothing works, everything eventually burns up
  2. Voltage too high - Everything explodes, then nothing works
  3. Frequency too low (voltage normal, or worse, high) - ALL transformers overheat. AC motors run slower in proportion to frequency, DC power supplies may not care.
Good Answers: 116
Re: DSDR
01/10/2011 4:01 PM
Entirely true. Do not search for DSDR to find where the question came from...
67model (2); JRaef (1); lyn (1)
