Previous in Forum: Motor Starting Problem   Next in Forum: STIR, Used to Analyze the Material Characteristics of XLPE Cables
Conductor Sag
01/08/2011 12:53 PM
If one tower is placed too much high, second tower is in valley area; how sag (i.e. conductor) can be maintained? Please describe procedure?
Re: Conductor Sag
01/08/2011 12:57 PM
Wait a minute. First scada and hmi and now this. This has to be homework. Either that, or you have just gotten a job you're not qualified for.
Which is it?
Re: Conductor Sag
01/08/2011 1:19 PM
If the towers are exactly of the same height the minimum distance between ground and conductor is exactly at mid-span and if one tower is higher than another the minimum clearance occours at someplace near the smaller tower. Also please note that towers of different heights can be procured if needed as well as separation between any two towers is not a fixed value.
Knowledge sharing is a WIN-WIN situation
Re: Conductor Sag
01/08/2011 1:31 PM
The curve is still a catenary. If the lower end is extended, it will rise to the same height as the higher end, and it will form a symmetrical catenary. My calculus book isn't handy, and it has been many years since I reviewed this; but I don't recall it as being too complicated.
Re: Conductor Sag
01/08/2011 1:34 PM
Register to Reply 4 comments
lyn (1); mountk2 (1); Tornado (2)
