Previous in Forum: Mechanical Properties   Next in Forum: Flow Indicator of Generator Cooling Water
IS2062 Gr. B
01/09/2011 6:28 AM
Can anybody give me Max. allowable stress for IS 2062 which needs to be used for Design of Pressure vessel as per IS 2825 ? Also, IS2062 Amendment in 2009 is different than values in IS2825 ?
Pathfinder Tags: IS2062
Re: IS2062 Gr. B
01/10/2011 7:39 AM
For this grade material the max. Allowable stress is 1274.2 kg/cm2 or 125 N/mm2
Re: IS2062 Gr. B
05/23/2013 7:30 AM
can you please provide the source where you have taken this value for allowable stress?
Register to Reply 2 comments
