Previous in Forum: Pull Out Force of 1.25" Bolt in 7075 Aluminum   Next in Forum: Weight of a Hollow Mild Steel Sheet Box
12 comments
Need to Build a Rotating Camera Device
01/10/2011 12:17 AM
Hi, I am working on a project that requires me to build what is essentially a camera monopod, but with a head that rotates 360 degrees (in 13 increments) and vertically 180 degrees (in 11 increments). This new device will be an improvement over an existing design, which uses servo motors (would stepper motors be better?). Problem with that device is that its made of wood and the movements are very inaccurate. The object is to take 100+ pictures which are then put together in a panorama-like picture. Money is not a problem, I should be able to afford the needed parts. I have no experience working with servo motors or robotics. Any helpful advice that gives me a better understanding or even tutorials that show me how to build something like this are welcome. I believe a stepper motor will be appropiate for this. Any advice on how I can find the right one?
Re: Need to build a rotating camera device
01/10/2011 5:03 AM
There are all sorts of options here. Presumably, the unit is to be mobile? Perhaps run from a laptop or similar?
Either servo or stepper options are viable. One option would be to look at Labview & either USB based control or perhaps compactRIO or single board RIO depending on the complexity/cost you're looking for. Go to ni.com here and root about.
01/10/2011 5:18 AM
Of course you could just buy one... like this for instance
Good Answers: 130
01/10/2011 6:38 AM
Or, if money is no object, you could invest in;
Catadioptric cameras
Lens and mirror based (catadioptric) cameras consist of lenses and curved mirrors that reflect a 360 degree field of view into the lens' optics. The mirror shape and lens used are specifically chosen and arranged so that the camera maintains a single viewpoint. The single viewpoint means the complete panorama is effectively imaged or viewed from a single point in space. One can simply warp the acquired image into a cylindrical or spherical panorama. Even perspective views of smaller fields of view can be accurately computed.
The biggest advantage of catadioptric systems is that because one uses mirrors to bend the light rays instead of lenses (like fish eye), the image has almost no chromatic aberrations or distortions. Because the complete panorama is imaged at once, dynamic scenes can be captured without problems. Panoramic video can be captured and has found applications in robotics and journalism.
Re: Need to Build a Rotating Camera Device
01/11/2011 12:18 AM
GCPad, I could of course buy one but it needs to go on some sort of a stand, and it will need to be modified a bit to for example take a vertically -90 shot. And these things seem to be too expensive, too heavy, and much more complicated than what I need. What I would like to do is try to make a simple machine myself, unless just buying something and putting it atop a stand would be a better idea? thanks for your tips. Much appreciated.
01/11/2011 12:18 AM
34point5, that is a very interesting idea, I didn't know about them. Must look up more info about these cameras. thanks
01/11/2011 8:56 AM
Here is a product I have used in building robotic camera prototypes.
http://servocity.com for pan tilt heads and servos. Reasonable prices. Wide variety.
How are you planning to trigger the camera?
http://pro.sony.com makes FCB block cameras that can be triggered by the code from the atmel processors (VISCA protocol)
Regards, Pete Olsen
Good Answers: 119
01/11/2011 4:20 PM
Yes, steppers would probably be better. Precise positioning without the need for validating the position for the precision you'll be operating at.
Google "Arduino stepper motor" to get tons of ideas about using open source arduino and its free programming environment as a controller for you system. There's tons of freely available code on the net and at the Arduino home page.
I'm currently building a 3D (3 axis) printer with steppers that's based on Arduino control.
Hooker
Good Answers: 130
01/12/2011 6:34 AM
Ummmm - Hooker, no offense, but the perpetual problem in film motion control, with steppers, is they might not step, due to the mass and balance variables of camera bodies and lens choice - and you don't know it hasn't stepped until "post".
Also, if he wants to do a pan in discrete increments, he has to match the stepper increments (by whatever ratio) to the chosen lens 'acceptance angle', or overlap and "fix it in post".
It can be argued (as many motion control failures have) that 1.80 is adequate resolution geared sufficiently for long lenses - but steppers loose resolution and torque with rpm.
Thus, as things become possible, film wants more, like faster pan (higher rpm) and longer lenses (finer increments). At this point steppers run out of combinations and the entire control system is scrap.
So ok, steppers look good on paper, but nearly all modern remote heads use encoded brushless motors because of "variables" in - well - just about everything you can poke a stick at.
Taken another way- steppers are "reinventing the wheel" like the original UK "Hot Head", which is circa 1980, and so 'old hat', I can't even find a web reference.
Similarly, steppers are long gone from CNC, bar foam cutting toys.
Then again the OP is doing it in wood maybe you're right.
Good Answers: 119
01/12/2011 10:02 AM
Good points, all, 34.5, and no offense taken.
But I stand by my recommendation. I was thinking mostly in terms of the mechanics and a lack of seeming concern about cycle or process time, and not taking into consideration recording "movies", just discrete snapshots. And the implication that money is no object but technical ability to throw together a complete system may be lacking.
Anyway, as one who used to breadboard systems like these for a living (research machinist at NASA) I don't see a big deal to put together a hefty enough mechanism to handle torque and position requirements for moving a small to moderate sized camera around with relative precision. The arduino system is robust enough (programatically) to aim the camera, with whatever lens, per the parameters described. Multiple Arduino programs could easily be made available and uploaded to accommodate the desired lens focal length/"acceptance angle" for a discrete session.
I will absolutely grant you that encoded motors with feedback validation would be the cat's meow but I didn't feel that the OP's original description of the task warranted that. Maybe they'd be Revision B once the initial mechanism is proved? But that's what design review sessions are all about, right?
Hooker
Good Answers: 130
01/12/2011 4:30 PM
Yep - and its all a bit 'open' when you don't know all the other factors like payload and operating parameters - or even where the OP is (so the operating environment, through to which suppliers one might point to).
It might be equally valid, or more so, just to tell him to buy a small rotary table or indexing head.
Good Answers: 128
01/12/2011 7:30 PM
Friends,
A small factor that should be added to the mix: Let us assume that the first order approach has 13 horizontal increments, each with 11 vertical increments (totaling 143 images). When the vertical angle puts the camera lens parallel to the horizontal axis, each one of its 13 pictures centers on the same space, just at 13 different angles of rotation. In writing the code or program to move the camera, a second order approach would change the number of horizontal increments, with it approaching 1 (or 2) as the vertical angle goes from 0 to either +90 or -90 degrees. The entire area could be covered with about 88 images (and maybe less).
--JMM
01/14/2011 11:34 AM
Maybe something like this could be adapted reasonably
http://photoshipone.com/ps1-products/
34point5 (3); Anonymous Poster (2); GCPad (2); Hooker (2); jmueller (1); peteolsen (1); raggededgge (1)
You might be interested in: Stepper Motors, DC Motors, Brushless Motors
