Previous in Forum: Need to Build a Rotating Camera Device   Next in Forum: Slotted Insulator To Electrify Field Tractors
Weight of a Hollow Mild Steel Sheet Box
01/10/2011 12:17 AM
How do I calculate the weight of a hollow mild steel sheet (1.6 mm thick) box of lenght 1.79 meters X 0.83 meters X 0.2 meters ?
Abizer
Re: weight of a hollow m s sheet box
01/10/2011 12:25 AM
(Density of mild steel per mm3) * [(1790* 830 * 200) - (1786.8 * 826.8 * 196.8)].
01/10/2011 12:31 AM
First calculate the area (l x w) of all the sides. You'll end up with square meters. Multiply that by the metal thickness in meters (.0016m). That will give you a small part of a cubic meter. Multiply that by the weight of a cubic meter of steel, which can be found with a Google search.
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
01/10/2011 11:16 PM
Thank you friend for the help.
Regards,
Abizer.
Abizer
Register to Reply 3 comments
abizerie (1); MoronicBumble (1); Tornado (1)
You might be interested in: Utility Meters, Flow Meters, Lux Meters (Light Meters)
