Previous in Forum: Slotted Insulator To Electrify Field Tractors   Next in Forum: Cairo Basic Wind Speed
Mill Tolerance for SA 516 Gr 70
01/10/2011 4:42 AM
for calculating min plate thickness required for pressure vessels, which one of the following should be considered in case of mill tolerance? as per asme sec8 div1 UG-16, """ (c) Mill Undertolerance. Plate material shall be ordered not thinner than the design thickness. Vessels made of plate furnished with an undertolerance of not more than the smaller value of 0.01 in. (0.3 mm) or 6% of the ordered thickness may be used at the full design pressure for the thickness ordered. If the specification to which the plate is ordered allows a greater undertolerance, the ordered thickness of the materials shall be sufficiently greater than the design thickness so that the thickness of the material furnished is not more than the smaller of 0.01 in. (0.3 mm) or 6% under the design thickness.""" or as per asme sec 2a, table A1.1, (SA-20)
vgsh
Re: mill tolerance for SA 516 Gr 70
01/10/2011 5:42 AM
Welcome to the world of "code" language, which is slightly less bizarre than "legalese."
(After all, it could be "educationese", so count your blessings.)
