Previous in Forum: Sitrans CU02 Alarm Unit with AS 100 Sensor   Next in Forum: Radio Link That Can Function Underground
Condensate Pot in Pressure X'mtr For Water Service
01/11/2011 12:13 AM
hi all!
I'm working in a CFBC power plant. I have observed a pressure transmitter mounted in fedd water line at Economizer inlet which employing a condensate pot. Is it right to place a condensate pot. what I usually observed that only for those condensable gases service could be used a condensate pot. Does it affect the pressure measurement? Thank you for your help.
New I&C Engr.
Re: Condensate pot in Pressure x'mtr for water service
01/11/2011 12:54 AM
condensate pot is usually used to protect transmitter from high tempurature, so in economizer tempurature is almost 80 to 95 C temp so you have to need to protect transmitter sensor from continues high temp.
just you check the installation of condensate pot and transmittter.
01/11/2011 6:17 AM
thank you sir for your answer. now i know why..yes, feed water has been heated at dearator stage. it has passed through 6 numbers of heaters before economizer.. once again thank you sir.
