Previous in Forum: Copper Loss of Transformer   Next in Forum: 3 Generator in Parallel
8 comments
Fire Pump
01/11/2011 2:00 PM
I WANT TO KNOW THE CORRECT CONNECTION FOR FIRE PUMP AS PER NEC, IEC, UL AND ANY OTHER INTERNATIONAL CODES......
IF SOMEBODY GIVES ME ANY REFERENCE CAD OR PDF FILES I WILL APPRECIATE
Good Answers: 140
Re: FIRE PUMP
01/11/2011 2:10 PM
Do a Google search on "NFPA 20". you will find loads of downloadable presentations on the net that talk to this.
Now... having said that, you need to KNOW what code is in effect in the region in which you intend to install this pump and then you need to ensure the pump is installed to that code.
Re: FIRE PUMP
01/11/2011 2:12 PM
connection is same whether it is NEC,IEC,UL or NFPA.
Re: Fire Pump
01/11/2011 3:56 PM
so, whats the connection???????????????
Good Answers: 804
Re: Fire Pump
01/11/2011 4:47 PM
Line to Line, Load to Load...
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: Fire Pump
01/11/2011 6:25 PM
Oi! Turn the bleedin' noise down, Pipsqueak. Some of us are trying to get some kip! <Splutter>
Essex jobs for Essex yobs! <Burp>.
Good Answers: 181
Re: Fire Pump
01/11/2011 7:26 PM
Good to see you're well Pete, did you send Chrimbo with Auntie Sall?
Good Answers: 29
Re: Fire Pump
01/12/2011 12:09 PM
Jockey pump may be hooked up backwards south of the equator.
Good Answers: 140
Re: Fire Pump
01/12/2011 3:43 PM
Yes... but only if an "Anti-Coriolis" effect device is in series with the jockey pump.
Anonymous Poster (2); JRaef (1); North of 60 (2); RDGRNR (1); Stinky Pete (1); TonyS (1)
