Previous in Forum: Fire Pump   Next in Forum: Vector Surge Relay
3 Generator in Parallel
01/12/2011 12:09 AM
if the existing two generator are already synchronized by the use use of auto synchronizing panel and it need 1 more generator with the same rating.. how i can connect the new generator to the 2 generators??
any diagram, material or websites?? thx.
Re: 3 generator in parallel
01/12/2011 12:34 AM
carefully.
Charlie don't surf.
Re: 3 Generator in Parallel
01/12/2011 2:58 AM
take the voltage reference from the common bus where the other two generators are synchronised and take it to the synchronisng panel of Gen-3.
-Vijay
You don't understand anything until you learn it more than one way.
01/12/2011 3:10 PM
Dnt knw abt existing genset capacity rating & Generator control panel main busbar along with synch scheme protection settings for existing . Do check your control wiring scheme from qualified commissioning and control engineer before any modification. However, The new Genset shall be capable to for parallel operation and command control panel will be responsible for parallel operation from new genset with new generator control panel . Also, take advice from your local consultant along with manufacturers for addition of new panel with existing generator control panels.
Register to Reply 3 comments
Safdar Khan (1); stevem (1); vijaymail_electrical (1)
