You need to refer to the textbook for the value of synchronising torque and power. Why would you operate at leading power factor? A good AVR, with under-excitation limiter and correct settings, will keep you away from loss of sync. If you have a chart for the +Q area, which is properly drawn and accurate, you can graphically construct the -Q part.
