Previous in Forum: For Turbo Generator Protection   Next in Forum: Generate the Electrical Energy.
Switching Current Sensor?
01/15/2011 12:19 AM
switching system design that can automatically OFF the other generator on low load demand and ON it if the demand is high... any diagram or circuit??
is this sensor out in the market that i can buy??
Re: SWITCHING CURRENT SENSOR?
01/15/2011 3:11 AM
Try searching "current sensing relay". There are several ways to go about it.
Re: Switching Current Sensor?
01/17/2011 12:40 AM
i think you are asking about power management systems. Yes, this can be achieved thro PLC systems. Using IO controllers and current feed from relays. You can configure the numerical relays to send analog outputs in the range 4-20mA to the PLC and in turn PLCs will decide when to switch on/off the generator depending on the load which is already programmed into that.
You don't understand anything until you learn it more than one way.
Register to Reply 2 comments
