Previous in Forum: How to Calculate Thickness of Concrete Casing in Penstock Pipe ?   Next in Forum: Sand Castle
14 comments
Rotating Building
01/15/2011 9:42 AM
i need some specific details about the rotating building in dubai .. im a first year student in civil engineering and i have a project about this topic
Re: rotating building
01/15/2011 9:48 AM
You will retain more information if you search for and find it yourself, instead of asking us to do the work for you.
A quick search produced many results. Try it.
01/15/2011 10:03 AM
i searched for it and i didnt find any deep information ! all i found is that the building is constructed around a central core and each floor is composed of individual pie-like sections that are pre-built and hoisted up the central core ..and this is not enough!
01/15/2011 10:09 AM
Keep searching. Good luck.
Have you tried architectural publications?
01/15/2011 10:13 AM
thank u but i hope someone else will help me ..
01/15/2011 10:15 AM
Pardon me, but it sounds like you want someone else to do the work for you.
Bye.
01/15/2011 10:22 AM
nop but being in my first semester i need a little help to have A+ on my project..
if u dont wanna help me its ok .. but maybe someone else will have
Good Answers: 74
01/15/2011 11:02 AM
There is a video among these links which gives lots of information on various aspects of the Dubai rotating building.
Bruce
01/15/2011 11:17 AM
thank u .. i saw them all before
but i wanna surprise my teacher by going deeper in the constructions ...and i thought u guys would have more info ..so anw thanks again!
Good Answers: 179
Re: Rotating Building
01/15/2011 3:05 PM
Visit the "Engineering News Report" (ENR) or "ASCE" websites, and you'll find what you require.
01/15/2011 3:26 PM
thank u :)
01/15/2011 7:57 PM
From some of the descriptions, "static utilities" such as elevators and plumbing are located in the stationary core. So they wouldn't be a big special problem. Electrical service to the rotating parts could be done via copper rings around the core, with moving brushes or rollers following around the rings. An analogy would be a slip-ring motor.
There are also such things as hydraulic commutators that can feed several lines to a rotating assembly, such as a crane. Conceivably the idea could also work for water supply and sewage, but it would be challenging to implement it.
01/15/2011 9:13 PM
Good Answers: 183
01/16/2011 2:59 PM
Where does it turn ? May be under a heavy earth shudder but then the rotation will not be around a verical center line ! Oh yes, the guy turned during the jump. I see now the realtionship. Now for the original question. It can be (as it was said) as in an excavator where there are distribution rings as for electric current but considering the core diameter it could be quite difficult to maintain such seals tight. I consider as more probable (but I can be wrong since I do not detain the truth) that each part of the pie has a "service unit" which is connected automatically with the water supply and the sink when the "pie" is in the right position. Several such "connectors" can be placed on the periphery.
01/16/2011 8:07 PM
Whoever has control over the position of each floor should pay higher rent. The folks on the other side should pay less. Or would they have block meetings to vote on which way to turn the floor?
Does the building profile really intercept enough wind/solar to generate 40MW?
Register to Reply 14 comments
ba/ael (1); CaptMoosie (1); JANOO (5); lyn (3); nick name (1); Tornado (3)
