Previous in Forum: Rust Prevention on AISI410 Hardened Surface   Next in Forum: SJ275
Aluminium
01/17/2011 4:18 AM
Dear all
We are doing Development for melting turning and milling scarp.
Process Called:
Aluminum melting process
Turning and milling scarp Melting process
Spec:
Aluminium Thickness: 0.05mm
Density :90kg/m3
Normal Process:
If we melt directly with crucible or refractory furnace 30% will burn out to oxide and become a dross
Process Called:
Spec:
Density :90kg/m3
Normal Process:
If we melt directly with crucible or refractory furnace 30% will burn out to oxide and become a dross.
our aim:
To get 83% of yield in aluminium so that we used a chemical for melting
Process :
In a refractory furnace melt following salt
Sodium Choride
Merato Potash
Calcium floride (or) florospar
In a molten salt bath immerse the turning after pre heating 200'C.
Problem We faced :
a)After melting salt to liquid stage we added aluminium scarp,as soon as we added aluminium scarp.salt bath become semi solid.
The requirement for us, chemical should with stand 700'C mean while it should not react with aluminium and it should be stable.So that every time we add aluminium in furnace it should comes out in outlet value,But the chemical should be stable. the density of aluminium is higher then salt we feeding inside the furnace.So the aluminium goes under the salt so there will no be dross.But we failed in trail.kindly do the needfull for us
Pls suggest a suitable economical salt for this process.
This discussion was "closed" on 01/17/2011 8:58 AM. No new comments are allowed.
Message from admins:
Duplicate. Please see original here: http://cr4.globalspec.com/thread/64784
Re: aluminium
01/17/2011 4:26 AM
Duplicate thread alert.
It's "scrap," not "scarp." ("Scarp" is a geological formation like a "cliff.")
Good Answers: 21
Re: aluminium
01/17/2011 6:49 AM
Hire a good firm to help you. This process is done everyday.
Register to Reply 2 comments
