Previous in Forum: Gear Box Type   Next in Forum: Telephone Keypad Stuck at Cold Area
9 comments
Gas Turbines in Action for Pumping Gas
01/17/2011 4:57 AM
What are the basics of a Gas turbine for gas pumping units,where the quantity of gas to be pumped is low,and distances small
Namaste
Re: Gas Turbines in action for pumping gas
01/17/2011 5:28 AM
Is this gas, as in vapor, or is it gasoline? What inlet and outlet pressures at the turbine/pump/compressor are needed?
01/17/2011 5:36 AM
natural gas
Namaste
01/17/2011 5:38 AM
The Natural Gas transportation method in compressed form,where d drive is done via a gas turbine
Namaste
01/17/2011 5:42 AM
CR4 Admin - email address removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
Namaste
01/17/2011 5:45 AM
Basic Data is not with me,what all specifications are reqd for designing the complete setup,how do I proceed wid d backward calculation procedure
Namaste
01/17/2011 7:08 AM
I don't yet see your situation clearly, but it sounds as though you're receiving NG (natural gas) from some pipeline source at rather low pressure, and compressing it into cylinders (CNG = compressed natural gas) at some pressure on the order of 100-150 psi. If so, the device you want is a compressor. If you Google "natural gas compressors" you can probably find many vendors, with capacity data to match your requirements, whatever they are.
01/17/2011 7:52 AM
thanx for ur advice,i'll put up d relevant data and lets c wat happens,2mrw is d meeting where all d specifications would be discussed
Namaste
Good Answers: 181
01/17/2011 10:51 AM
Suggest UzN http://www.transl8it.com/cgi-win/index.pl?convertPL thN we wiL undRstNd U
01/21/2011 7:36 AM
The project is now completely understood and the distance is not small,its aroung 600 kms of transmission pipelines and there are lateral lines in between. Its a huge project nd I am jus a pass out from Engg(* mnths of experience under my belt) but that ws purely designing and not pipelines,wish me luck guys I am in on a big one
Namaste
Register to Reply 9 comments
Deepak_mechanical dude (6); TonyS (1); Tornado (2)
