Previous in Forum: Telephone Keypad Stuck at Cold Area   Next in Forum: Screw CAP/Plug
HVAC System Start Up Sequence and Interlocking
01/17/2011 11:12 AM
For HVAC chilled water system, can we have interlocking in the electrical panel for system start up sequence as below...
Cooling Tower Fans with Condenser Water Pumps
AHUs
Primary & Secondary chilled water pumps with chiller
Re: HVAC System Start Up Sequence and Interlocking
01/17/2011 1:44 PM
You can have anything you want! Its called Building Automation Controls. http://en.wikipedia.org/wiki/Building_automation
01/19/2011 11:58 PM
Interlocking is required for safe operation. Chiller normally started with cooling tower followed by condenser cooling water pumps
Chilled water flow across chiller after ensuring condenser and chiller has adequate flow rate the compressor is switched on.
Earlier systems it used to be interlocked electrically between the pump starter and compressor starter .The compressor starter will start only when the Cooling water and chilled water pumps are on and adequate flow is ensured.
You might be interested in: HVAC Services, HVAC Ductwork, HVAC Repair Services
