Previous in Forum: HVAC System Start Up Sequence and Interlocking   Next in Forum: Butt weld.
Screw CAP/Plug
01/17/2011 2:14 PM
Am looking for caps/plugs to cover socket head cap screws - M3 and M4.
The requirements are
The outermost surface should be anodized aluminum. Going for a custom aluminum part is definitely expensive. So am planning to use a rubber CAP/Plug that snap fits onto the OD of screwhead / allen opening respectively and then glue aluminum shim on top of it.
Please let me know your suggestions, links to off the shelf rubber or plastic caps/plugs that you have used.
Good Answers: 181
Re: Screw CAP/Plug
01/18/2011 12:43 AM
It took less than 30 seconds to find these on Google. Try it yourself!
Re: Screw CAP/Plug
01/19/2011 2:12 AM
"The requirements are" so why do they require this? Find out before you get cheep!!!
