Previous in Forum: Use of NGR   Next in Forum: lpg or diesel to cng conversion
Transmission
01/18/2011 12:34 AM
Can we connect 11 KV Rectiformer to 11 KV Generator directly without using a transformer?
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Re: Transmission
01/18/2011 1:51 AM
Both rating is 11KV, then for what we have to use transformer? Is it for isolation between both sides?
If you can't find a way, make one........
Re: Transmission
01/18/2011 3:06 AM
yes for isolation purpose and to avoid frequent tripping of turbine due to fault in dirstributor side
Re: Transmission
01/18/2011 3:12 AM
''yes for isolation purpose and to avoid frequent tripping of turbine due to fault in dirstributor side''
You alredy explained well what is the need/use of a isolation transformer, then why can't you try that.
Re: Transmission
01/18/2011 3:17 AM
a comparative is to made between requirement of transformer and cost of transformer. how to make that? what is the role of transformer between generator and distributor end if voltage level is not required to be changed?
Register to Reply 4 comments
