Previous in Forum: Reactance Changes with Fault Currents   Next in Forum: Transmission
9 comments
Use of NGR
01/18/2011 12:08 AM
Hi all,
I have a query regarding use of NGR. As per my knowlegde, NGR is used to prevent the fault current entering into the equipment in case of Line to Ground fault in the outgoing of the equipment such as gen, Trafo, motor etc. Also, it also used to limit the fault current flowing into the ground. But this works only in case of trafo. What abt in case of generator, bcoz the fault is occuring next to the source and the generator will start feeding the fault and in this case how the NGR limits the fault current.
Please correct me if i am wrong.
-Vijay
You don't understand anything until you learn it more than one way.
Good Answers: 181
Re: Use of NGR
01/18/2011 12:36 AM
Search Neutral Grounding resistor or NGR in this forum, there are lots of threads on the subject.
Re: Use of NGR
01/18/2011 12:45 AM
NGR is the sound I make when I am really frustrated about something (but with a few more Rs, like NGRRRRRRR!)
India - Member - New Member
Good Answers: 164
Re: Use of NGR
01/18/2011 1:05 AM
It is language dependent....we Bangaloreans go AYYYAYYYYOOOOO !
Re: Use of NGR
01/18/2011 1:42 AM
Ha! Thanks for the good laugh!
Re: Use of NGR
01/18/2011 3:51 AM
Pick the balls others dropped!!!!........
Good Answers: 164
Re: Use of NGR
01/18/2011 4:40 AM
Good Answers: 131
Re: Use of NGR
01/18/2011 9:21 AM
Draw out a 3-phase elementary drawing of the system. If there is a NGR in the generator neutral, any fault to ground that is fed by the generator would have to flow back through the resistor. The value and thermal capacity of the resistor are sized to handle the limited current (for example, 400 amps for 10 seconds, plenty of time for protective relays to operate).
Good Answers: 170
Re: Use of NGR
01/18/2011 12:16 PM
I fear your understanding is a weebit incorrect. The purpose of NGR is to reduce the fault current during an earth fault (it could be an L-G fault or an L-L-G fault too). It will work well both in case of transformers as well as in the case of generators. More so in generators, as the single line to earth fault current in generators can be more than the three phase fault current and thus, it obviates the need for an NGR to limit the single line to ground fault current fed by a generator. More concerns would also be towards core damages in rotating electrical machines like generators during an internal line to ground fault.
Re: Use of NGR
01/18/2011 10:52 PM
What u told is correct. But how it will limit the fault current. Bcoz resistor is placed in the neutral and current flows from the generator. You mean since the neutral is the nearest free path for current flow, it will try to flow thro that path. So if we place the resistor in the shortest path, the fault current will find difficult to flow.
Am i right?
-Vijay
Register to Reply 9 comments
Anonymous Poster (1); electricalexpert65 (1); kvsridhar (2); Mikerho (2); PeterT (1); TonyS (1); vijaymail_electrical (1)
