Previous in Forum: Pole Mounted Transformer   Next in Forum: Install CT Before or After Breaker?
About Transformers Testing
01/18/2011 1:50 AM
tel me about transformers testings how many types & how it ill do
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Re: about transformers testing
01/18/2011 2:01 AM
- No load test
- Full load test
- Insulation resistance testing
- Voltage regulation testing
- Tan delta testing
- Various types of transformer oil testing is given below.
A) DGA
B) Moisture content in oil testing
C) BDV Testing
D) Furan Analysis
E) Interfacial tension testing
F) Corrossive sulphur checking (Chemical analysis)
To know how to do this all tests, you just search in google.
If you can't find a way, make one........
01/18/2011 2:26 AM
Insulation resistance testing, Open circuit test, Short circuit test, Core balance test, Vector group test, Turns ratio test, Tan delta test, Sweep frequency resonance analysis, Oil breakdown voltage test, all auxiliary protections checks like bucholz, PRV, MOG, OTI,WTI, OLTC operations. These are the tests usually conducted as routine tests as well as Pre commissioning tests.
-Vijay
You don't understand anything until you learn it more than one way.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: About Transformers Testing
01/18/2011 6:48 AM
IS : 2026
hithuanand (1); justinanto1987 (1); vijaymail_electrical (1)
