Previous in Forum: Going Green   Next in Forum: Solar Panels - Determine Rating, Power
Parabolic Trough Lens
01/18/2011 12:43 PM
How do I line up the focal point of a parabolic trough lens to track the sun?
Re: Henri
01/18/2011 1:06 PM
TOP technique.
You have not told us how elaborate your system is. Will this work for you?
[edit] I see admin has altered the title of your thread. No lens involved.
Good Answers: 58
Re: Parabolic Trough Lens
01/18/2011 1:19 PM
Check Mother Earth News. You can use photocells and motors, or small tanks and a heat-sensitive gas like freon. It can be kept simple.
mike k
01/19/2011 5:33 AM
Line it up East-West, tilted from the vertical by an angle equal to your latitude.
01/19/2011 6:09 AM
At the end of the trough, on the axis that it is rotating about, fix an assembly with a sheet to form a shadow and behind it two small photovoltaic panels:-
Use the power from the panels to drive a small bi-directional DC motor which is then geared down hundreds of times to rotate the trough.
As the sun rises a little light will fall on the top panel: use the current to tilt the trough up. If there is a period of cloud cover then when it passes a lot of light will fall on the top panel and the trough should tilt up fairly quickly. Vice versa as the sun falls.
01/23/2011 10:09 AM
since the sun travels at a set rate the cheapest way would be to set the angle ie up down and then use a geared motor drive to pan the unit to follow the path of the sun, then when the end travel has been attained fit a micro switch to return unit to start position then a timer to allow for night time then start again
Anonymous Poster (1); Doorman (1); mike k (1); Randall (1); Rixter (1)
