Four wire wye 2400/4160 system. Billing metering is FM 9S 3 element. Normal PT/VT connection is Phase to Ground. Customer wants to install a ground fault resistor and some of our engineers say that we can tie the wye point to the Line side of the GFR. I say no because we are not grounded per IEEE Standard C57.13.2. If we tie the wye point to ground then we will have phase and voltage errors due to the GFR. If the customer want to use a GFR then I say we meter on the high side of the transformation that in this location I think is 115 kv but I could be mistaken and it might be less. Does anyone know what the errors might be if we meter on the low side and tie the VT/PTs to ground?
