Previous in Forum: GRP Pipeline   Next in Forum: Spring Loaded Ball Valve
Calculating CMF in HVAC
01/19/2011 2:45 PM
how can i calculate CMF and duct size in HVAC?
farrukh saleem
Re: Calculating CMF in HVAC
01/19/2011 2:49 PM
Q=VA
01/19/2011 2:55 PM
what is Q v ? A ?
farrukh saleem
01/19/2011 5:33 PM
What is CMF?
01/19/2011 5:45 PM
it's CFM not CMF
CFM air flow in cubic feet / min
Q = V X A in CFM
V = Air velocity in feet per min
A = Duct cross section area in squire feet
01/19/2011 6:50 PM
According to the LynDoor Intergalactic Dictionary CMF is the Country Music Factor that affects the duct size. Take the square of the inverse of the duct area and multiply that by the funk factor.
This gives you the duct size.
Good Answers: 58
01/20/2011 8:52 AM
HELLOOOOO
CMF - Cubic Minutes per Foot
Multiply the length of the country music track (minutes) by the length of the duct (feet) then divide by 3.14159265358979323846264338327950288419716939937510
01/22/2011 9:16 AM
Very easy every Ahu has a cfm rating ask manufature then get a ductulater and that will tell you the amount of duct and size.Also ductulator will keep the volume within the cfm rating for the amount of straight run and turns needed also the amount of drops.the ductulator will also help in sizing the return.the ductulator is a little hard to understand at first.you can get the ductulator at any supply house that sells duct ie.. Anderson
Register to Reply 7 comments
Anonymous Poster (2); Doorman (1); farrukh saleem (1); KJK/USA (1); lyn (1); tom.b (1)
You might be interested in: HVAC Ductwork, HVAC Services, Duct Heaters
