In the quest for answers about pipe insulation I have run into the sister concern about pipe expansion of directly buried pipe.
Much research revealed that the provision for underground pipe is not as vital as above ground pipe.
It was found that any provision for expansion would be a useless system component because the ground friction will restrain the pipe from expansion contrary to the behavior of above ground pipes.
However, some respondents have alerted about the need for it. This requires further confirmations from those in the field or from those having expertise in this area through education or research.
The following cases need to be addressed. All systems carry ordinary water and the pipes run at 3 feet or more depths. There are no issues of frost, freezingor perma frost.
Is there a need for expansion provision for:
1) For bell and spigot uPVC underground pipes carrying unheated, uncooled water.
2) For glued cPVC underground pipes carrying unheated, uncooled water.
3) For glued cPVC underground pipes insulated with HDPE carrying hot water at 75 degrees celcius.
4) For seamless steel underground pipes insulated with High Density Polyethylene insulation carrying chilled water for HVAC system.
5) For ERW steel pipes underground carrying unheated, uncooled water.
Thanks
