Previous in Forum: Selecting Wind Blade Profile   Next in Forum: design vacuum = 5 mbar
Pump with Pressure Differential Controller
01/26/2011 1:49 AM
I am looking for a pump (electric or diesel engine) with built-in differential pressure controller. I.e. pump with built-in controls to start-up and shut-down with pressure drop on the downstream pipeline.
Can someone point me in the right direction?
Re: Pump with Pressure Differential Controller
01/26/2011 5:35 AM
Use a differential pressure transmitter, a trip-amplifier and a relay contact in the pump's starter circuit for the simplest solution. The transmitter and trip-amp will need a (typically) 24VDC power supply fed off whatever mains voltage is present at that location.
01/27/2011 12:55 PM
Application ! Application ! Application ! Your use would help. Fire system pumps are one application. See : http://iotaautomation.com/admin/upload/FM%20APPROVED%20FIRE%20PUMP.pdf
