Previous in Forum: Automobile   Next in Forum: Standard Screen Sizes
Tank size
01/26/2011 10:54 AM
I have a 12 KW generator with a 24 Hp. LP fired engine. What is the smallest tank size that I can use in gallons.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Tank size
01/26/2011 11:13 AM
I don't know the proper formulas, etc. but I'm guessing your going to have to provide more information to get a meaningful answer. Such as; how much LP gas does the gen set use for a given load, and how long do you want to be able to run it on one "tank" of fuel?
Tom D.
Re: Tank size
01/26/2011 11:18 AM
Here is an excellent reference for you:
Here it is, the generator make shouldn't matter, the numbers will be roughly the same.
Re: Tank size
01/26/2011 12:38 PM
I'm with tdesmit. Until we know how long the "tank" is supposed to last, the answer would be 1.
Re: Tank size
01/26/2011 5:45 PM
Since it is a emergency Generator no one know how long a power outage could be. I would think that if I could get 48 hours it would do. It does run once a week for 10 min. I'm more concerned about the draw so I do not get freezing. In the book it says that it needs 240000 BTU. I figure that I need around 2.6 gals per hour. I'm not sure about the draw down on the tank. I'm thinking that I may need around a 100 gal tank?? That 2.6 gals is at full load.
Re: Tank size
01/26/2011 6:17 PM
My book says 24HP consumes 122256 btu over 48 hours.
Good Answers: 137
Re: Tank size
01/27/2011 8:19 AM
It can be as small as you like, provided you don't mind filling it up frequently.
Codey
Register to Reply 6 comments
Codemaster (1); digger104 (1); kramarat (1); lyn (2); tdesmit (1)
