Previous in Forum: Tank size   Next in Forum: Calculating R-value for Vacuum Insulated Glazing
Standard Screen Sizes
01/26/2011 11:45 AM
Dear members, would you please advice me on a reference for standard sizes of perforated metal screen. (opening hole size).
Thanks in advance
Re: Standard screen sizes
01/26/2011 1:56 PM
It really depends on the application of the screen. Could be micron size, could be inch size.
Can you please describe the application in more detail.
01/26/2011 2:58 PM
the screen will be used for raw sewage strainer
I want to know different sizes available (micron/or inch) to select for the application
mentioned.
01/26/2011 8:21 PM
You should do a search for a "raw sewage strainer", then, after you know at least SOMETHING about the subject come back for help.
01/26/2011 9:47 PM
Mr P.Engine try this or that 1)do a search on global spec for wire mesh 2) http://www.mcnichols.com/viewer.htm hope it answers your need. Regards, Ray
klearzen
Good Answers: 137
01/27/2011 8:30 AM
Can vary from about 6mm to 25mm. Maybe more for a preliminary screen, depends on job specifics.
Also important is the design - whether it's 1 dimension (bars) or 2 (mesh). Nowadays 2 dimensions is often specified as it does a better job. On a bar screen objects much larger than the nominal spacing can get through e.g. plastic backing strips from "feminine hygiene products" (to put it coyly!)
Cheers.........Codey
Codemaster (1); jack of all trades (1); klearzen (1); lyn (1); power engine (1)
