Previous in Forum: Charge Transfer   Next in Forum: Has the Post Office Taken Over the Internet?
Mobile
01/27/2011 11:36 AM
HI dear,
we have Nokia 5130, it became dead due to water penitrate from keyboard side,
Actually the mobile drop in the wet area you can say wet floor, not full water, and we did not pulled out its batter after it become we, it worked 4 hours nomally and after that it is dead, no charging, no light, totally dead even we replace battery with bew ones.
We need the help tips and procedure to find out the fault section.
Munawer Hussain,
Jan27,2011
Pathfinder Tags: mobile
Re: Mobile
01/27/2011 11:47 AM
You have told us the phone is dead.
I believe DEAD will be difficult to fix, even for the capable members of CR4.
According to Miracle Max, if it is completely dead the only thing to do is go through his pockets looking for loose change.
Re: Mobile
01/28/2011 12:13 PM
i dont have loose chain in my pocket..ha ha
Re: Mobile
01/27/2011 1:41 PM
What type of water? If it is salt or chlorinated water, forget it it is dead. This stuff corrodes the delicate internal electrical parts like crazy.
If it was clean or fresh water then there MAY be a chance. Disassemble it as much as possible and put the parts in your hot water cupboard (or equivalent warm, low humidity environment) for a day or two to try and dry it out. If you are really, REALLY lucky the phone may start working again, if not then it is time to get a new phone.
The SIM card should be ok in either case, but if it was salt water the SIM card needs to be carefully wiped down as quickly as possible to prevent damage and loss of your saved phone numbers, etc.
Re: Mobile
01/28/2011 12:11 PM
The water was chlrinated,
We have dried it by hair drier, but the condition of mobile is still.
Register to Reply 4 comments
Doorman (1); jack of all trades (1); Munawer Hussain (2)
