Previous in Forum: Making Plastic Prototypes   Next in Forum: Compression Molding
Specific Pressure Required
01/29/2011 1:19 AM
What's the specific pressure required for moulding a rubber product by compression moulding.we are having a hydraulic press with 800 ton capacity.it has 4 rams with dia 320mm each.the platen size is 1200x2200mm.Our product is a W shaped fender with cross sectional area 1507.785 sq.cm.the mould size is 1750x500 mm.
Re: guest
01/29/2011 1:55 AM
Re: Specific Pressure Required
01/30/2011 8:19 AM
You obviously have no idea how the compression molding process works. You need enough pressure to close the mold. After that IT DOESN'T MATTER!!!!!!!!
Once the tool closes, it steel against steel, so it could be one pound or one million pounds, IT DOESN'T MATTER.
Hire a molding consultant. Maybe he can explain it to you.
Register to Reply 2 comments
