Previous in Forum: Specific Pressure Required   Next in Forum: Etching on Stainless Steel
Compression Molding
01/30/2011 8:22 AM
what all considerations are required for a new manufacturer who would like to produce rubber marine fender of about 400 kg weight with a mold of size 1.75x.5m through compression molding.the sp.gravity of rubber compound was found to be 1.25.what tonnage should the hydraulic press have?what is the specific pressure required?
Re: Compression molding
01/30/2011 8:29 AM
Hire a consultant! Ask your equipment supplier. Do some research on your own. You have not even begun to supply meaningful information. Don't be so lazy.
Specific Pressure
01/30/2011 11:03 PM
From the equipment supplier part,i got the details of hydraulic press.the press tonnage is 800 ton.the platen size is 1200x2200mm.ram dia=320mm,no. of cylinders=4.what's the pressure and force requirement?
01/31/2011 11:29 PM
Good Answers: 130
01/31/2011 11:46 PM
Look Junior, What Lyn is telling you is go back to the threads you started and read the $%^((&^%# answers you were given!
And I wholeheartedly agree with Lyn!
34point5 (1); Junior Engineer (2); lyn (1)
