Previous in Forum: Need API std. 2550 ?   Next in Forum: CS and CS NACE
Plastic Part Tensile Strength
01/29/2011 3:46 AM
I have seen a number of plastic part that support long term tensile load being broken after a few years. CAn any one recommend what is optimum safety factor for plastic such as Nylon? Also , what is optimum safety factor cast aluminium ? Thank you.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Pathfinder Tags: Nylon plastic strength
Re: Plastic Part Tensile Strength
01/31/2011 3:37 PM
Optimum safety factor is dependent on the application for any material...
Fans of Old Computers - ZX-81 - New Member Popular Science - Cosmology - New Member United States - Member - New Member APIX Pilot Plant Design Project - Member - New Member
02/27/2011 11:51 AM
Let's add another thought as well -
you might have a plastic selected with the properties you think are best, but this might only be likely in one type of environment -
Example - there are lots of various sanitizer systems to make "swimming pool water" - some plastics do very well during long time exposure to this long list of possibilities and some do not do well at all with some of the possibilities -
Question: if your product was going to be sold through distribution where you will never know who your customer's customer's customer is or what they use to produce "clean" pool water - don't you want to be sure to make your product(s) from materials that will live through the worst case scenerio?
Give some holistic thought as well to the DISTRIBUTION elements and the final ENVIRONMENT where your final product will have to live -
Just our two cents
Skippy and Buzz
http://skippyandbuzz.blogspot.com/
Register to Reply 2 comments
