Previous in Forum: Woodstove Humidity   Next in Forum: Water Evaporation
To be corrected the industrial coating system
01/30/2011 1:41 AM
Please can i get help from CR4 experts to correct theses below given painting system which is given below and on more question developed is regarding the differentiating criteria between cyclic temperature condition and constant temperature condition for considering paint system P & Q.
PAINT SYSTEM
Base Material
TEMPERATURE
Surface Preparation
Primer
Intermediate
Finish
Total DFT
A
Un-insulated CSAmbient to 120
0C
Sa 2.5 (Rz= 50 - 75 µm)2-pack Epoxy zinc rich (organic zinc)2-pack Eoxy MIO2-pack acrylic polyurethane
275 µm
75 µm150 µm50 µm
B
Un-insulated CS121
0C to 200 0C
Sa 2.5 (Rz= 30 - 75 µm)2-pack ethyle zinc silicate (inorganic zinc)NASilicon acrylic coating
135 µm
75µm(30µm X 2) = 60 µm
C
Un-insulated CS201
0C to 400 0C
Sa 2.5 (Rz= 30 - 75 µm)2-pack ethyle zinc silicate (inorganic zinc)NASingle pack silicon coating
125 µm
75µm(25µm X 2) = 50 µm
D
Un-insulated CS401
0C to 540 0C
Sa 2.5 (Rz= 30 - 75 µm)Single pack silicon coatingNANA
50 µm
(25µm X 2) = 50 µm
P
Un-insulated CS Vessels and Cyclic temperature PipingAmbient to 400
0C
Sa 2.5 (Rz= 50 - 75 µm)Titanium Modified Inorganic Co-PolymerNANA
200 µm
(100µm X 2) = 200 µm
Q
Un-insulated CS Constant operating temperature PipingAmbient to 565
0C
175 µm
175 µm
E
Un-insulated SS(-196)
0 C to 200 0C
(Rz= 30 - 50 µm)2-pack epoxy phinolic primerNA2-pack epoxy phinolic finish
200 µm
100 µm100 µm
F
Un-Insulated / Non fireproofed Galvanized steelAmbient temp. (Rz= 30 - 50 µm) or mordant /etchning solution2-pack zinc free epoxyNA2-pack acrylic polyurethane
125 µm
75µm50 µm
K
Insulated CS Cryogenic servicesUp to (-4
0C)
Sa 2.5 (Rz= 50 - 75 µm)Epoxy phenolic primer2-pack Epoxy MIO2-pack acrylic polyurethane
500 µm to 600 µm
(300µm to 400µm)150 µm50 µm
L
Insulated CS Cryogenic services(-4)
0 C to lower temperature
Sa 2.5 (Rz= 50 - 75 µm)Silicon base primer (Hi-Temp 1027 Cryogenic type)2-pack Epoxy MIO2-pack acrylic polyurethane
150 µm50 µm
M
Insulated CSUp to 150
0C
Sa 2.5 (Rz= 50 - 75 µm)Epoxy phenolic primer or epoxy-novolac (Severe wet environment and critical process)2-pack Epoxy MIO2-pack acrylic polyurethane
500 µm to 600 µm / 600 µm to 700 µm
(300µm to 400µm) / (400µm to 500µm)150 µm50 µm
N
Insulated CSAbove 150
0C to 400 0C
Sa 2.5 (Rz= 30 - 75 µm)Silicon base primer (Hi-Temp 1027 or Thurmaloux 70)NASilicon acrylic coating
(30 µm X 2) = 60 µm
O
Insulated CSAbove 400
0C to 648 0C
Sa 2.5 (Rz= 30 - 75 µm)Silicon base primer (Hi-Temp 1027)NASingle pack Silicon based coating
(25µm X 2) = 50 µm
P
Insulated CS and SS Vessels and Cyclic temperature Piping(-196)
0 C to 400 0C
200 µm
Q
Insulated CS and SS Constant operating temperature Piping(-165)
0 C to 565 0C
175 µm
175 µm
E
Insulated SS(-196)
0 C to 200 0C
200 µm
100 µm100 µm
G
Fireproofed (with concrete) Galvanized stractural steelAmbient temp. (Rz= 10 - 15 µm) or mordant /etchning solution2-pack poly amide epoxy (for touch of HDG)NANA
NA
H
Fireproofed (with concrete) Stractural Carbon steelAmbient temp.Sa 2.5 (Rz= 50 - 75 µm)2-pack poly amide epoxyNANA
75 µm
75 µm
User-tagged by 1 user
Good Answers: 130
Re: To be corrected the industrial coating system
01/30/2011 1:58 AM
Isn't this a duplicate?
01/30/2011 3:31 AM
Isn't this homework?
01/30/2011 2:09 AM
You can't say it is duplicate but you can proceed if you want to incorporate something is wrong in given coating system with respect to service condition .....please
"Without goals you are like a ship that has set sail with no destination."
01/30/2011 3:54 AM
Actually this is a attachment of QCP and this QCP need to be approved by client, so i have forwarded to CR experts to correct these coating system prior to final submission. And i am not so expert to select the coating system with respect to service condition.
Thanks,
01/30/2011 4:05 AM
What incentive would we have to do your work for you?
01/30/2011 4:38 AM
Please send me a check for $50,000 US and a paint brush.
I'll be there on Thursday.
34point5 (1); Adeel Ahmad (2); kramarat (1); lyn (2)
