Previous in Forum: Dissolved Oxygen in Boiler Feed Water   Next in Forum: Advantage of Centrifugally cast product to forged product
17 comments
Bonding Rubber to Metal
03/30/2007 6:53 AM
We want to know how we can make good adhesive bonding natural rubber to metal, who can strong enough to pull for 12 kg/cm2, thank you.
Re: Bonding Rubber to Metal
03/31/2007 1:02 AM
Companies that sell rubber roofing membrane have many types of adhesives for any substrate. A simple phone call to one of them will get the infor.
John
12/01/2008 2:01 AM
UNITED RUBBER INDUSTRIES (I) PVT.LTD.
We, UNITED RUBBER INDUSTRIES (I) PVT.LTD' (U.R.I) has pleasure to introduce – as one of the ISO 9001:2000 & TS 16049, certified manufacturer and exporter of complete range of High Performance Silicone Rubber Hoses/EPDM Rubber Hoses/Rubber to Metal Bonded Products/MOULDED PRODUCTS/END FITTING HOSES/EXPANSION JOINT/BUSDUCT BELLOWS/BUTYL VIBRO DAMPNER/INSULATIONSHEET/CORKTAPE/EXTRUDEDPRODUCTS/BRAIDED RUBBER HOSES/RUBBERISED SPACERS/SUSPENSION INSERTS/BUSHES FOR TRANSMISSION LINES .Our R & D is recognized by Ministry of Science and Technology, Govt. of India. 'U.R.I' has a Multi-disciplined team – based throughout the organization and is committed to working in full partnership with its customers.
'U.R.I' has got a very articulated marketing network and operation system to satisfy Int'l STD quality, therefore 'U.R.I' is an "ESTABLISHED" "HONOURED" and "MOST PREFERRED" supplier to industries like Automotive / Defense / Power and Transmission / Railways etc. We can cater for a long production runs or one-off unusual type moldings integrated into "JUST IN TIME" implementation. To further strengthen our market presence towards attaining a global leadership, we are too keen to establish business association with you for promoting our products in your country under your able leadership and guidance.
We have been working hand in hand with many customers of ours in meeting the expectations of their customers. This has given impetus and helped us to reach these heights.
We sincerely solicit your partnership in developing the products required by your end or your customer's end.
Our products are used with many engine manufacturers, Truck manufacturers, earth moving equipment manufacturers around the world needless to say our export department has fully geared up to receive your valued RFQs.
We are sure; your response will open a new beginning of business association with URI which will certainly benefit both of us!
With kind regards
Dinesh
GM - Export
United Rubber Industries (I) Pvt. Ltd.
(ISO 9001:2000 / TS 16949) Certified Manufacturer & Exporter)
Jai Valenkani Ind. Estate, Mira Bhayander Road,
Mumbai 401105/India
Tel: 0091 22 28145134/35/36- Ext.220
Tel (Direct) - 9122 - 28143724
Fax: 0091 22 28184614
e-mail: exports@unitedrubber.net
Website: www.unitedrubber.net
03/31/2007 2:53 AM
Would look under CYANOACRYLATES, but would call with specs to be sure...
http://www.extremeadhesives.com/guide-plastics.php
12/01/2008 2:04 AM
With kind regards
Dinesh
GM - Export
Mumbai 401105/India
03/31/2007 6:50 AM
What type of metal? It makes a big difference as to the nature of the bond achieved. What surface area is involved. Is it going to be a permanent bond? Will it have to maintain the load for a long time? Will it be cyclical loading? All these factors count.
Can you cast a coupling into the rubber piece? And then use a mechanical means to join the two pieces? Just a thought. The application will give you the solution.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
03/31/2007 9:30 PM
In the automotive industry,what you need is a Phosphate Operation, to coat the metal with something for the primer and adheisve to bond to. The next step is the curing process that is done with various molds at various temps. After the item cools to room/air temp.is when you can obtain a true P.S.I. reading.
Chuck Old Hippie
12/01/2008 2:07 AM
With kind regards
Dinesh
GM - Export
Mumbai 401105/India
03/31/2007 7:54 AM
From my limited experience I would say make up test samples and set up a weight to test all under the same conditions. You can try rubber cement (contact adhesive) Follow the instructions- thin layer on both surfaces, air dry for one or two min. bond with pressure...
Super glue (Cyanoacrylate)
Q-bond. or....
vulconizing the rubber onto the metal.
And lastly try polyurethane adhesive
I am sure there is other adhesives that will do fine, but to my knowledge these are the ones that I will test. Good luck...
"Remember... if women don't find you handsome, at least let them find you handy." - Uncle Red
03/31/2007 8:14 AM
i agree with using contact cement- it's awsome stuff. just a note, though: rubber cement and contact adhesive are not the same thing. rubber cement is in the category of contact adhesives, but is not as strong as products marketed specifically labled contact cement.
03/31/2007 8:48 AM
In my country it is the same stuff... Sorry, I stand corrected then... I am referring to the strong solvent based stuff you use to fix shoe soles, stick sanding paper to a disc or fix ruber to rubber (puncture fixing)
03/31/2007 9:41 PM
You want to look for Thixotropic adhesive. Don't use Evostick.
03/31/2007 9:56 PM
What type of process are you talking about ? If it is for the suspension units for the Auto Industry,I`m interested.
Chuck Old Hippie
03/31/2007 1:30 PM
To access the Polyisobutene (PIB) dedicated pages
and improve your adhesive / sealant performance with Polyisobutene (PIB)!
Enjoy reading and please do not hesitate to send me your feedback.
Best regards,
François Bauduin
VP Adhesives & Sealants
industry-manager-as@specialchem.com
Your best guide!!
03/31/2007 9:03 PM
Let me know of the problems that you are having, and maybe we can help each other out
Chuck Old Hippie
04/01/2007 12:25 AM
We bond EPDM rubber to polished chrome surfaces of shower door hinges using cyanoacrylate adhesives. These support the thick glass doors weighing over 20 kg
Christopher Devereux
12/01/2008 1:49 AM
With kind regards
Dinesh
GM - Export
Mumbai 401105/India
12/01/2008 1:59 AM
With kind regards
Dinesh
GM - Export
Mumbai 401105/India
Reply to Forum Thread 17 comments
Anonymous Poster (3); BrainWave (2); Chinasavvy (1); Chuck Ramsey (3); MUKULMAHANT (1); oomsarel (2); SolarEagle (1); unitedrubber (4)
