Previous in Forum: stirling engine   Next in Forum: 2003 Chevy Cavalier Won't Crank
Treatment for Preventiong Heat Treated AISI410 Rusting
01/30/2011 11:58 PM
One component of SS 410 stainless steel toughened (near to get a surface hardness max of 45 HR) is found to be rusting in just a day @ salt water environment. This component is subjected to a normal food cutter environment.
Will appreciate your ideas on what chemical treatment could be done such that there would not be any change in the external dimensions.
VCK
Good Answers: 97
Re: Treatment for Preventiong Heat Treated AISI410 Rusting
01/31/2011 3:41 PM
Where is it written SS 410 is recommended for salt water environments?
01/31/2011 11:13 PM
ceramic like they put on engine exhausts and other stainless stuff.
http://www.plasma-tec.com/ceramic_chrome_oxide.shtml?gclid=CNiTuO2L5qYCFU5a7Aod1WB51Q
01/31/2011 11:34 PM
Stainless steels in general need to be passivated after machining before exposure to corrosive environments. This is to remove iron from the surface. Some of this iron is picked up from the tools used to machine or hold the part. Passivation can be done by most surface treatment houses and is not expensive.
02/01/2011 2:05 AM
CR4 Admin - email address removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You may share your email address via the CR4 internal messaging system if you wish.
Best Regards and have a lovely day!
Register to Reply 4 comments
129CBRider (1); bwire (1); GeoffD (1); KrisJacobs (1)
