Previous in Forum: Motor Stopped   Next in Forum: Do I Add High Point Vent
Torque Spec
01/31/2011 9:04 AM
What is the wet torque spec for a M36 x 110 Socket head cap screw
Good Answers: 183
Re: Torque Spec
01/31/2011 11:27 AM
Material ? Surfaces treatment? Why torque ? Application ? Machines ? Structural ? Loading ? Free length ? Lubricated ? Not lubricated ? How many bolts in an assembly ? You answer then you get ONLY a recommendation without any warranty.
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
Re: Torque Spec
01/31/2011 5:52 PM
Hello "Guest",
Before anybody can provide you with a torque value, you have to state how tight you want this fastener to be. Just like almost everybody else who requests a torque spec, you've not done this
After this and only once you've provided the necessary additional information, a torque target can be provided. However, this could be quite useless if your bottom line is a reliable bolted joint.
Have a look at this recent post for relevant background: http://cr4.globalspec.com/thread/65152/Torque-Tightening
Best regards, HeviiGuy
