Previous in Forum: Trailer Riddle   Next in Forum: Salmonella bacteria
CNG and LPG Compatibility for Cars
03/30/2007 1:11 PM
Hi,
I'd like to know if a car that has been modified to use CNG can also use LPG.
I'm considering converting my car for CNG use and this info could help me to decide because dual use means easier sourcing of fuel.
Also what are the other issues involed. e.g. Safety
Thanx
Pathfinder Tags: alternative fuels car CNG LPG vehicle
Re: CNG and LPG Compatibility for Cars
03/30/2007 9:48 PM
"I'd like to know if a car that has been modified to use CNG can also use LPG."
The carburetor will likely have to have additional modifications for LPG.
03/30/2007 11:37 PM
Dear,
CNG (compressed natural gas) is basically Methane CH4 while LPG (liquefied petroleum gas) is mixture of Propane C3H8 and Butane C4H10. Both have different calorific value and thus need different air fuel mixing ratio for proper combustion.
Both fuels could not be handled by one kit, you need two separate and dedicated kits for each fuel with interchange switch.
Abdul Rahim.
03/31/2007 4:40 PM
Stan, by "kit" he means fuel cylinder, control valves, tubing and mixer(carburetor). The mixers can be mounted in series to simplify the induction piping and to preclude having to switch throttle linkages too. There is even a LPG mixer that is built into an air cleaner housing that mounts right onto a gasoline carburetor. If there is a CNG mixer that is shaped like a gasoline carb, that would greatly simplify your install.
04/01/2007 11:05 AM
LPG basically has more btu, therefore a smaller jet size is required....But you should be able to integrate the two systems, with a little ingenuity...If I had to choose between the two, LPG is preferable...More bang for buck...
04/02/2007 6:46 AM
Why not LNG?
Israel - Member - New Member
04/02/2007 6:52 AM
Why not LNG?
I ask a question? I receive the answer? I react......:)
Register to Reply 6 comments
Abdul Rahim (1); Anonymous Poster (2); SolarEagle (1); Stirling Stan (1); vdik (1)
