Previous in Forum: Residual Current   Next in Forum: Differential Relay
Power Factor Panel Issue
02/01/2011 4:56 AM
Dear Engineer; Actually i was working on installing a power factor correcting on a factory and i heard an info i just want to confirm it: We all know that power factor correcting panels reduces the Kvar. and you get some discounts on the bill What I heard is that with each 1 Kvar u SAVE, 10 Watta increases in ur consumption. Which means reducing Kvar will increase ur Watta which results a higher bill..but with the discounts u gain ...the bill will be approximately the same... What do u think?
Good Answers: 181
Re: Power Factor Panel issue
02/01/2011 5:11 AM
What do u think?
Your talking out of your hat
02/01/2011 6:52 AM
Yes Capacitor Bank reduces the " KVar " .
(From The Thread http://cr4.globalspec.com/thread/30702/power-factor)
Lets take an example of to understand somewhat the concept of power factor correction.
We have a 500 VA UPS. It runs 2 computers each having Load of 0.9 A and P.F 0.6 at 220 VAC system. When we add a third computer, UPS fails to provide power to these three computers.
UPS Fails Why?
For a Single Computer at P.F = 0.6
Real Power = 220 x 0.9 x 0.6 = 119 W
Apparent Power = 220 x 0.9 = 198 VA
When both computers were on we have
Real Power = 238 W
Apparent Power = 396 VA
When the Third Computers was added then
Real Power = 357 W
Apparent Power = 594 VA
Since Apparent Power of UPS is 500 VA and at this P.F i-e 0.6, 594 VA are required so UPS fails to fulfill the requirement.
Now a Capacitor is added to improve the Power Factor from 0.6 to 0.95 then Current Reduces to 0.5693 A.
Now for a single system
Real Power = 220 x 0.5693 x 0.95 = 119 W
Apparent Power = 220 x 0.5693 = 125.246 VA
Now If three Computers are added to the system then
Real Power = 220 x 0.5693 x 0.95 = 357 W
Apparent Power = 220 x 0.5693 = 375.738 VA
System will run quite smoothly as Requirement reduces from 594 VA to 376 VA.
By improving the P.F
1.We reduce the size of Transformers, cables etc.
2.We are very efficiently utilizing the System Power.
Also see the video
http://www.youtube.com/watch?v=AI_e3dF14eg
02/01/2011 7:34 AM
thank you very much for ur reply...actually u made things clearer...but till now i couldn't get an answer. Does the Capacitors we may say..consumes 10 watt for each 10 KVAR they save...which means for the current we save in VA..do we consumes current i n Kw to make these capacitors work maybe?
Good Answers: 170
02/01/2011 8:24 AM
There is something called "dielectrc watt loss" in each capacitor. It could vary from 0.2W/kVAr to even 2 to 3W/kVAr, depending upon the technology. You have to select a capacitor with a low watt loss. But, that could cost more. Check with capacitor manufacturers' catalogues.
Register to Reply 4 comments
electricalexpert65 (1); Salar (1); therealabdo (1); TonyS (1)
